2007 Buick Lucerne Intermittent Stalling
patt8009
There are many posts about this issue already but I have not seen an answer as to why this seems to be a problem with this vehicle. Stalls while driving down the highway, stalls while sitting in park, stalls at low speeds, etc...Sometimes several weeks go by with no problems, then last time several times in 1 day. Always when the engine is hot, usually starts back up within 5-10 minutes. Dealer says no codes, after several hours of testing they replaced the ICM, took it home and same thing only on this stall 45 minutes and no start. Back at dealership who is now not returning my phone calls, probably because they have no clue what is wrong with the car. Has anyone had any luck figuring this out? Again, seems like a common enough problem that the dealer would have seen this before.
Hi Patt,
Welcome aboard! And thank you for signing up... If you don't get a response from one of our Lucerne owners or mechanics - please ask this question again in the Buick Customer Service forum:
http://buickforums.com/forums/forums/105-Buick-Customer-Care-Representatives
...in order to escalate your issue. This problem needs to be resolved and if your dealership isn't helping - perhaps customer service can send you in the right direction...
Thanks Sal, may try customer service. The dealer can't figure out the problem. After doing some digging (I bought this used) another area dealer had the car in for the same problem and never figured it out either.
Hi, I have the same problem. I have 2003 Buick lesabre, car ran fine with no problems. I left it parked at my moms for 2 weeks next time I drove it it stalled on me driving 5o mph. I pulled over, popped the hood took off engine cover and saw a lot of acorns on top of the intake/upper plenum. I think a squirrel or chip munk chewed on some wires but I can't find any chewed on. Its driving me crazy tring to fiqure this out, cuz sometimes I can drive the car for a whole day and it won't stall once, other days all it does it stall on me, like 5-6 times just getting to work in morning. I don't think its a fuel problem cuz I replaced the fuel pump because the gauge didn't work, replaced the fuel filter and with the car running it has 50psi fuel pressure. If anything I think it might be spark related. Online ive read that the problem might be: coil pack, ignition control module, crank position sensor, mass air meter, but I don't have any dtc's to tell me what exactly it is. I don't wanna start throwing parts into it without knowing exactly knowing what is the problem. It just really weird that the car ran fine and 2 weeks later it stalls. I noticed that rite before it happens, the cruise control stops working and the traction control light comes on?
So I posted this on the customer service page with no response. Latest update, after second trip to dealer in May when they "cleaned all electrical connections and replaced a couple" car ran fine until 2 weeks ago, now same problem again. So, to recap, since 2007 this car has been to 2 different dealers with the same problem somewhere between 4 and 7 times...unfortunately my state has no lemon law coverage for used vehicles. Checked NHTSA website and there are similar complaints but involved accidents...and yet GM is silent on this obvious problem. This is why people in the 70s and 80's stopped buying cars from the big 3...
Reason I bought this car was the longevity of the 3.8. I drive 35-40,000 miles annually for work. Does me no good that the engine is great if I can't drive it when it's hot.
I had a problem like that with one of my 3800 cars. in my case it turned out to be a cracked Crank Position Sensor. Of course, it could a few other things too, but in my case that fixed it.
You've got to really inspect the wires all the way from the PCM / ICM to the critical sensors (crankshaft, camshaft, MAF, MAP, knock and O2.) Pull the loom and crusty tape off the wire harness and look closely at any point where the harness passes over a hard metal edge or around metal brackets. On my 2006 CXS with the 4.6L engine I found multiple places where the harness was grounding out, looking closely under a light you could see bare copper exposed on multiple wires. I strongly suspect that GM cheapened their wire specification around 2006 because I never had issues with insulation on previous GM vehicles. Insulation on critical wires all over my 2006 bakes and flakes off like hard plastic, when you bend a wire the insulation just immediately cracks and falls off. During my recent engine rebuild I had to completely reconstruct the main harness and the one section under my intake that I didn't address during the rebuild caused exactly your symptoms to creep up last week. Last night I rebuilt that last bit of harness under the intake and the problem is solved. In my case I suspect my crankshaft and bank 1 camshaft sensors were grounding out intermittently.
Same situation only ive replaced crank sensor, tested and evaluated various wiring and components, trimmed down rear seat hinge ect.. the things that GM calls for in bulletin. Right after it dies it sometimes clicks as if starter solenoid is bad but will start back up eventually and if i turn motor over by hand it seems to start easier (making me think wiring to crank,cam sensor and/or cam sensor possibly. Only thing i have found is fuel pump relay did seem to be only relay that was warm while driving it today after it died. Some where on internet people were saying to replace fuel filter every 30k miles but its in the tank attached to fuel pump and apparently the fuel pressure sending unit/module is in there too. Upon checking fuel pressure few days ago i got just above 50psi and wasnt having issues. Now im getting about 60. Im thinking fuel pump is failing and causing relay to draw too much amperage, the only wacky part is how it sometimes wont turn over after dieing. Car is 07 with 58k miles im second owner the previous owner took very good care of care and kept records.
Sounds like good info. Thank you for posing this. Im going to tear into it tomorrow to inspect wiring under hood. Ive replaced crank sensor and coolant sensor as it went out once once after stalling suddenly on highway(no mifire or rough running motor it just dies) and usually just clicks as if the starter solenoid is bad but starts eventually afterwards(seemes to help if i turn motor over by hand or manipulate wiring to cam sensor). ive also replaced battery in it after these issues started. When i replaced crank sensor as far as i could tell that wiring looked ok but the plastic conduit fell apart making me wonder if the wires were overheating as it seems to do it more often when at operating temp so after inspection i installed new conduit. I really want to see the wiring behind exhaust manifold as i feel the issue is most likely there(13 yrs old and the conduit was that brittle)
As you mentioned the fuel relay did you pull it and fuel fuse to check for any burn or melted areas in the fuse box at the bottom, if it is damaged then it's likely to damage the fuel pump over time. Not sure if you have the V6 or V8 as both have some separate issues. It may be something to consider a scan on stored codes that might suggest a area to focus on. Last item is to be mindful of critters as they can cause havoc to harnesses.
I did check i seperated the fuse box and looked through with good light. It looked ok. There are no codes active or stored. its the 3.8 gen3. Ive inspected all the wiring under back seat only place i havent looked over throughly is under coil by exhaust. I think im going to check that tomorrow for burnt wires. When i replaced crank sensor i put new conduit on the wires that needed it but i didnt remove coil to inspect wires near exhaust. The coolant sensor went out recently one time when it died on highway so ive replaced that. Thank you for responding and im glad ive found this forum. Ill keep everyone updated if i find the issue.
UPDATE i did pull relay and fuse for inspection before seperating box.
Assume so but just confirming. There's a Chilton manual online in link below go to post #40 for information. It has the TSB that may take some time to go through but you may see something that could be useful along with wiring schematics.
Free Chilton Online Repair Manual
I have the same problem did you ever get you fixed??
It's a 2016 post so no reply will be coming. Post details on your problem as it's a 6 year gap and not sure what the OP real problem was.
You are asking yourself a question.
Found out something today regarding this elusive gremlin of a problem with random intermittent stalling and starting problems hopefully it helps people dealing with this issue with there buick. First off my names keith i am a automotive technician at a independent automotive repair shop that specializes in imports mostly european and japanese makes but we pretty much work on everything even the occasional masarati. Im accredited but not ase certified and i have 10 years experience in the automotive repair industry doing diagnostics and R&R work.
Here is my experience dealing with time vampire of a issue on my mothers 2007 buick lucerne . Symptoms were the car would stall intermittently and would crank and not start or start and run rough and have issues staying running . So i agreed to look at the car and have spent around 2 weeks doing different tests to confirm and condemn what the issue is and repair it accordingly like a professional technician would and not just throw parts at it making educated guesses.
I took my moms car to work and it took 3 days before the symptom even happened the car stalled on me then had trouble starting but no codes were thrown so i drove it around with a scan tool hooked up recording live data of course it would not stall again and everything looked fine on sensors and live data so i stopped doing that after 3 days of driving . I tested fuel pressure it was fine right at 50 psi 55 psi on run. Swapped out the fuel pump relay with one of the door lock relays and hit the lock switch to determine if it was the fuel pump relay it worked fine tested the relay with a dvom meter tested fine .
Cleaned the mass airflow sensor and throttle body then looked at the data and what the throttle position sensor was reading all tested fine within range . Did a tb relearn and a crank and cam relearn using the scan tool car ran better but i could not get it to duplicate stalling again so i returned the car to my mom told her i did not have any issues and to drive the car 2 days go by she calls said it did it again at her work in the parking lot and the car would not start like the battery was dead but she could not give me accurate info on if the car would turn over or not anyways she said she had to jumpstart the car.
So i take it again of course run more tests . Tested the battery and charging voltage all test fine even though the charge voltage looked a little low at 13.8 volts she said it stalled out after hitting a couple bumps so i suspected the ignition tumbler or contact switch in the ignition due to the recall gm had . Ordered a aftermarket dorman tumbler pinned it out to her key drove it for 3 days no issue gave it back and told her to keep any weight off the key car ran great for 2 weeks then boom again so i take the car. Look at fuel trim and drive it nothing until 3rd day car stalls on me afternoon im also in arizona and it in 111 degree heat she also mentioned it seemed to do it on hotter days. So i suspected a failing alternator but could not confirm it.
It still tested fine so back to the drawing board looked at the TSBs on the car looked at the forums noticed that gm put a winshield washer fluid heating coil that caused this cars battery to drain when it was first sold they had to do a firmware update for. Well we live in arizona so yea pointless to have so i pulled the 60 amp fuse for the system retested the battery voltage and charge voltage and alternator tested fine even better battery went from 12.32 to 12.54 on core voltage and from 13.78 to 13.99 on charge voltage . Suspected the alternator was failing and was not maintaining a magnetic field on hot days but could not confirm it and its a $200 alternator so swapping it on a guess is out of the question and tests were fine car seemed better unplugging that system . .
Drove it for a couple days car ran great . Keep in mind my mother replaced the ignition module on this before i looked at it and i did some much needed service because the car needed it and my moms pretty good on keeping up on service. Did a coolant flush removed the orange dexcool and put in universal yellow. Yea i know gm recomends dexcool i dont care from my experience every gm car ive owned if i flushed and put regular antifreeze or universal yellow or had the money universal red later down the road i would not have LIM gaskets fail or have to change out the head gaskets or the heater core so i do this on all gm vehicles ive owned and recomend it .
Not to mention dexcool oxidizes into a brown sludge from a little air exposure . I recomend this from personal experience . Flushed the brake system . Flushed powersteering fluid and changed fluid due to gm vehicles having issues stalling from the powersteering pumps failing or fluid breaking down putting more of a load on the motor ect ect. Anyways riding with my mother today the car stalls while shes driving wont start at all so i push the car out of the road try it nothing and the lights on the dash go completly out when trying to start it. Which that was a new symptom to me .
So other then spending time figuring out where the starter relay is i just did a hard reset on the car by disconnecting the battery and de energizing the systems its hot out and was not exactly sure if it was security related or what but it gave me the info where to look anyways hook the battery up car starts right up so i get home start looking at the electrical diagram and i notice that it has two relays that control starting the car R3 relay which is just your standard 4 prong relay which btw my mother already replaced and would not explained the surging and stalling issue but looking at the electrical system R6 relay would explain it if the relay was weak or sticking due to sending power to parts of the motor to have the car run.
So i pulled out R6 micro relay notice its a standard 4 prong relay and think WTF gm really? And honestly this makes no sense for any reason to me other then a engineering to fail standpoint so people take the thing to the dealership and have there techs not figure it out and rack up the bill hey my thats opinion. Why i think that is most of the relays in the fusebox exept 3 of them are normal relays . Does not make sense from a money saving or even space saving stand point and then to have this control important systems to the engine and be one of the three micro relays only sense it makes is its engineered that way and not only that so you cant pinpoint the problem right away so people throw parts at there car. not to mention its not a common relay just sitting on store shelves .
Changed it out car runs fine tested the old relay ohm test is barely in range limits which expains why heat may cause it to fail going to run it with the new micro relay will give a update if the car acts up again so no news is good news so to speak my advice is even though i dont recomend throwing parts is to change out the R6 relay in the fuse box under the hood unless you have the means and knowledge to test the relay its a $15 dollar part so if your going to start throwing parts at the car start with that .
If you have a scan tool look at the live data and learn how to read it first if you can scan tools are cheap and getting cheaper you can go down to walmart now and buy a hypertough bluetooth scan tool for $50 that works with any android phone its a rebadged scan tool made by autel. not to mention get 1 manufactures package for free so you can even pull dealer codes for many cars even code transponder keys for some i use this personally and even use it at work so i dont have to wait for the main scan tool at work if someone else is using it and i dont want to use our old mk808 scan tool that needs a new battery plus i can do pretty much everything with my ap200 autel scantool that the mk808 can
its only $50 but worth every penny walmart should have them listed as the HT200 or HT500 best money for your dollar if you have a android phone you can scan do what most professional techs can . My cost so far other then a ton of time and tests being a professional technician would be around $100 for a updated ignition tumbler that did not fix the issue but in my opinion was a good update due to the recall and design gm used. A $15 micro relay and fluids used to service the car not to mention plugs that the car needed anyways . That was my issue will share any update if the car acts up again also going to pull specs for this micro relay and see if there is a normal 4 prong relay that can be used then make a adapter for it why gm did this makes no sense other then a engineered to fail standpoint in my opinion
There is a tsb about fuel pump relay however my issue ended up being the connection at red wire on 14 pun connector that goes to ignition control module. The evap lines also rusted all the way through at the plastic clamps that route them which was hard to find as you can't see any rust until removing the clamps. Hope this helps. Hang in there it took me 1 yr to find and fix it all after dealer mis diagnosed it.
I had similar to this. Finally it popped the code for the crank position sensor. I replaced it myself and issue was solved.
Before it would stall, Tachometer would go to zero.
