GunnyP
A Regular
- Aug 1, 2016
- Cleveland, OH
- Buick Park Ave Ultra 1993
Just finished installing KYB Struts-Plus on 93 PAU w/ 86K miles. Torqued everything to spec. Returned knuckle to scribed marks to ease alignment. Noticed no difference in front end height although the ride leveler ran a bit extended after removing from jackstands and popping the leveling system fuse back in.
Sadly, although silent when in reverse gear when I place it in drive a loud "Tic - Tac - Tic" emanates apparently from the front passenger wheel well. And it is loud! Echoing noticeably off each home that I pass with tempo increasing with vehicle speed.
Jacked her back up, pulled the tire and hunted for any visible cause for the ticking but found nothing all the lines (brake, ABS) all were secure.
Aside from a two-day battle to get a knuckle mount bolt out, the install was uneventful. Nothing else on the vehicle aside from the driver side matching Struts-Plus was changed.
Defective Struts-Plus? An alignment issue?
