Hello all,
I have a 2013 Verano and recently my computer system has been on the fritz. I start my car with no issues but then my dash info area says I need to service pretty much everything on my car (Air Bags, Anti Theft system, Side Detection System, etc.). None of my gauges work either (gas, speedometer, rpms). The digital display for speed and gas do not work as well. My intellilnk and radio will also not come on. The car still drives fine and my lights and blinkers are on but I have no indication on my dash that they are on or working. The other issue is that sometimes it does this and sometimes it turns on with no issues at all. I called my local dealership and they told me they would have to charge me $100 for every service indicator that showed and I do not want to pay thousands of dollars if it's a simple corroded wire or something that simple. I have a friend that has a Chevy Cruze and his car had the same issues and it was a loose ground terminal connection. If anyone has any info on what this problem might be and could give me advice on how to proceed, I would greatly appreciate it. Thanks for reading and thanks in advance for any help you can give me.
