Dave S.
- Mar 14, 2013
- North Branch, MI
- 1997 Buick LeSabre Limited, 1991 Buick Park Avenue, 1990 Buick LeSabre Limited
I have a 1997 Buick LeSabre limited that has the automatic climate control feature. When we bought the car last year we noticed it took about a half hour for the air to start coming out the middle vents, it would only happen once in a while though. Right now it only blows air out the defrost and the floor vents. I read up on what the cause is and I can't trace it. I dropped the underside of the dash and the glovebox, I found the vacuum tubes that are supposed to open and close the blend doors, none of them have vacuum, I checked to see if there is engine vacuum and there is loads of it. I'm not sure if the whole programmer module (I think that's what its called) needs to be replaced, I couldn't figure out how to remove the box because I would have to drop the whole underside of the dash which has 2 bolts connected to the air bag compartment and under the module is the wires for the air bag and I don't want to ac idently detonate the air bags.
While I was under the dash looking at the actuators for the blend doors, I found a strange door behind the floor vents on the hump, I pulled it open while I had the car running and no air came out just louder blower noise. Does anyone know what this door is for?
I want to get this problem figured out ASAP because I live in southern Texas and its starting to get in the high 90's and with no air coming out the middle vents, a ride can be absolutely miserable.
I put my redneck skills to work while I had the underside of the dash off, I used a piece of bailing wire to hold the door open for the middle vents, air comes out now but not very strong. Is this because air is still coming out the defrost and floor vents?
