Rear Deck subwoofer speaker replacement
ltavara131
2012 Buick Regal
So I just bought a 2012 Buick Regal yesterday and one of the rear subwoofer on the rear deck has blown up. I’m not sure how remove the rear deck so I can replace it. Could anyone walk me through on how to replace it? Thank you so much guys!
Did you look inside the trunk to see if it is removed from underneath the deck?
Drop the rear seatbacks and look for a push-pin on either side
Seems like it's a lift up and slide toward the front thing.
But that's just from a look a while back.
Here's the diagram to remove the rear deck panel.
It was already posted here in the forum. I just put it in this thread because the original thread has so many different links and passwords so it's confusing. So don't shoot the messenger!
For those who are in need of the Chilton manual here's a example on how to obtain it legally and not have any copyright infringement, note this is a example for OHIO and you will need to check your city, state or educational resources for access.
Chilton Library | OPLIN
Thank you for also coming up with the copyright infringement solution.
You are being ignored by BoostedRegal 2.0 so I dont have to read your stupid comments anymore you loser.
Just noting that this information no longer exists on this domain and can no longer be shared. If a login to a system needed to be purchased to view data, it cannot be shared here freely.
It was said the repair manual was an unpaid subscription since it was free library material, so why was it removed?
Which speaker did you replace it with? Do you have the Bose system?
If it's free library material and can be accessed without payment, just share the link where people can sign up as it won't cost them any money. But sharing a password to a login is an issue.
There is no need to sign up to get the password. Here is the link to the Public Library website that publicly displays the password for ANYONE to see and use without an account.
