Sam14GS
- May 15, 2014
- Lake Worth, Florida
- 2014 Buick Regal GS
Does the whole bumper have to come off or just unbolt the top section so its off enough to get to the headlight assembly bolts ?
Also found this interesting video
Thanks for all the info everyone ! I left the 2 access caps off this morning, already dried out. Can't work on it until this weekend.
Just be careful when you pull ... there is at least one wire to disconnect, maybe more depending on how foglights and those GS vent lights are wired, if I recall the fog lights on mine were not an issue, but the other wire is for the air temperature probe. Be ready to disconnect as you are removing the cover.
Regarding your ballast question, I had a heavyweight bout with one of my leaky HID assemblies last winter and had to purchase a ballast at Autozone - there were two parts listed on the website within ten bucks in price, both supposedly for my 2012 GS. Naturally I picked the lesser expensive part and after going through the effort of installing it learned that it was incompatible. In the end I ended up paying the stealership $400 for the GM equivalent only to learn that the voltage output of the aftermarket ballast was not within spec. Thankfully Autozone took it back but I always wonder if I had chosen the other part if my problems would have been solved right there. I cannot remember the spec but the GM tech told me the voltage output of the aftermarket ballast was too high, for what it's worth...
would you please list the part numbers and instructions on how you went about halogen based assemblies? thanks.At the end of my story I simply ordered new Halogen based assemblies for both sides of my car, installed SilverStar Ultra bulbs and never looked back. It's been about 8 months and though my car doesn't look as cool without the LED DRLs I no longer have worries about condensation. The SilverStar bulbs do a fantastic job of lighting up the road especially on high beam, I don't miss the HID's and all their problems.
