chas
- Aug 7, 2019
- Kona
- 2019 TourX, 1990 F-150
Bought used (dealer demo, 7K miles) 2019 TourX a month ago. Like it a lot.....until this morning. Went outside to go to work and everything dead - doors won't open, and once I used the manual key, inside and no lights, no nuttin' - checked battery with voltmeter = 4.7V.....Wanting to try charging battery but see a 'glob' of cables/fuses/connections attached to the positive terminal and can't for the life of me figure out how to remove this massive 'glob'. Tried the few obvious nuts, loosened it up little, but no success.
See photo: the central 10mm nut with the red wire attached doesn't loosen up the black shelf holding all the cable terminals and fuses; the 10mm nut in the left lower corner, adjacent to the apparent terminal clamp is some sort of weird tightener for the cable clamp - loosening it makes the entire black plastic conglomerate move but doesn't really disconnect it; could force it more, but don't want to break anything. ANY IDEAS APPRECIATED!
In the long run, of course, need to figure out why the battery died. And have a bigger conversation with myself: much as i like the TourX (about the nicest car I've ever owned), buying it made me violate my 50+ years' rule of never buying a GM product (racist, I know) and right now - with an essentially brand new car not running after one month - i'm beginning to think that was a rule i shoulda never busted.
