Correct torque settings
Michael Caro
2003 Park Ave Ultra
For 2003 Park Ave Ultra front & rear brake bracket & slide pins & lug nuts
pplicationSpecificationMetricEnglish
Brake Hose Bracket Bolt
17 N·m
13 lb ft
Brake Hose to Caliper Bolt
44 N·m
32 lb ft
Brake Pedal Assembly to Booster Stud Mounting Nuts
23 N·m
17 lb ft
Brake Pedal Assembly to Cowl Stud Mounting Nuts
16 N·m
12 lb ft
Brake Pipe Fitting Tube Nut
15 N·m
11 lb ft
Brake Pipe Fittings at Master Cylinder Tube Nut
33 N·m
24 lb ft
Brake Master Cylinder Mounting Nuts
25 N·m
18 lb ft
Fastener Specifications​
ApplicationSpecification
MetricEnglish
Brake Caliper Bleeder Valve
13 N·m
115 lb in
44 N·m
32 lb ft
15 N·m
11 lb ft
Front Brake Caliper Bracket Bolt
185 N·m
137 lb ft
Front Brake Caliper Pin Bolt
85 N·m
63 lb ft
Park Brake Cable Guide Bolt
24 N·m
18 lb ft
Rear Brake Caliper Bracket Bolt
128 N·m
94 lb ft
Rear Brake Caliper Park Brake Cable Bracket Bolt
43 N·m
32 lb ft
Rear Brake Caliper Pin Bolt
27 N·m
20 lb ft
LUG NUTS:
Tighten
Tighten the nuts in a criss/cross pattern to 140 N·m (100 lb ft).
17 N·m
13 lb ft
44 N·m
32 lb ft
23 N·m
17 lb ft
16 N·m
12 lb ft
15 N·m
11 lb ft
33 N·m
24 lb ft
25 N·m
18 lb ft
MetricEnglish
Brake Caliper Bleeder Valve13 N·m115 lb in
Brake Hose to Caliper Bolt44 N·m32 lb ft
Brake Pipe Fitting Tube Nut15 N·m11 lb ft
Front Brake Caliper Bracket Bolt185 N·m137 lb ft
Front Brake Caliper Pin Bolt85 N·m63 lb ft
Park Brake Cable Guide Bolt24 N·m18 lb ft
Rear Brake Caliper Bracket Bolt128 N·m94 lb ft
Rear Brake Caliper Park Brake Cable Bracket Bolt43 N·m32 lb ft
Rear Brake Caliper Pin Bolt27 N·m20 lb ft
LUG NUTS:
Tighten
Thank you, MS. B.G.F.M.
