gpjlytham
- Nov 29, 2021
- 2001 Buick Regal
Hi All
2001 Buick Regal LS 108,000 miles. Hole in the valve cover, misfire and ticking noise.
The car was running great, then it started to misfire and the check engine light came on, then the engine started to make a ticking noise. My scanner shows a misfire in cylinder 3.
I thought it might be a bad coil causing the misfire so I swapped the coils to see if the misfire moved to another cylinder. It didn’t. so I’m fairly certain the coils are ok and a bad coil wouldn’t explain the new ticking sound.
I pulled the spark plug and it looks very old but looks ok (no damage or excessive gap)
I changed the oil to see if it had any metal in it. No metal, so nothing too catastrophic.
I filled it with new oil and replaced the filter and added some miracle engine cure to quieten the noise. But it still has the misfire and the ticking.
I now suspect a collapsed lifter so I’m taking the intake off and removing the valve covers.
The rear valve cover (one near the firewall) has a hole drilled in it and it doesn’t look like a hole drilled at the factory.
Q’s
Hopefully some of you have some idea’s.
Thanks
Q’s
- Is the hole, a factory hole?
- Why is the hole there? (no blow by at the oil filler cap on the front cylinders)
- Any thoughts on the ticking?
Thanks
