"The Dreamer" 2003 LeSabre Limited
We will send it out to have the oil pressure sensor fixed as soon as possible. Thanks!
in SPID/RPO, what are those codes for:
GFTV33 - ?
4HR69 - ?
They don't show up on this site.
+1
It may seem like its no big deal,but they have the propensity to start leaking badly at this point.
So once the pressure reading fails & gives false reading, they then can fail by leaking? What causes that failure sequence?
All I know is that I was lucky enough to notice oil by my passenger side front tire on my previous car (1997 Olds 88). Had I not noticed it it would have lost all or most of it's oil by the time the oil warning light came on. I had to get it towed home.
It's old and the plastic gets brittle. They're inexpensive and not that hard to change with the proper socket.
Looks good. Don't forget a good polymer wax protectant like Zaino. Easy to use & a good UV protection.
I gave my "Dreamer" its first bath since acquisition!
Very sharp looking. Make sure you use something with wax in it rather than dish soap or something, or preferably a wax after wash.
Meguiar's also makes an excellent product for tires called Hot Shine. 2 or more years ago I oversprayed some onto the road and you can still see it in the rain!
Thanks for the advice on cleaning stuff.
Where is the oil pressure sensor located?
Service worked on 2/21/22 by NTB:
-4 tires TBC Linglong Americas Epic Tour AS
-Radiator Coolant drain & fill
-Power steering fluid exchange
-Battery checked & advised:
+Door window motor regulator passenger side replaced
(went down quietly compared to 3 other windows!)
-(6) NGK NG3-3951 spark plug gap .060; V-Pro
-STD STA-7689 spark plug wire set replaced
-Wheel alignment
How so i fix this long, hairy speaker cover?
Not a lot of options and cutting it is the only way to remove it, how is left up to the owner. I would avoid a hedge trimmer or Sawzall, but to each their own.
Someone recommend sweater fuzzy shaver
It's kind of whatever works the best for you.
