JIMTMCDANIELS
- Mar 16, 2020
- 1998 Century Custom
Hi,
1996 Buick Century 3.1 130,000 miles, driver's air bag only.
Looking for a way to reset-turn off the dash Air Bag light after the bag deployed in a minor collision.
Already replaced and plugged in another Air Bag and the front sensor that is in front of the radiator, from a 1996 Century.
I've tried unplugging the battery cables for several days, and connecting them together, first with a resistor to drain any capacitors.
I do have a 2 books factory Buick dealer shop manual that says once the bag and any physically crushed sensor are replaced, to use a scan tool to reset the AirBag light.
I do have a scan tool BUT it does not do AirBags or even ABS.
I was hoping I wouldn't have to buy a more expensive scan tool yet so that's why I'm asking.
The shop manual does mention a Diagnostic Energy Reserve Module that is part of the system.
I'm wondering if like I can drain the charge in it to clear the code or if it's a hard set code that definitely requires a scanner?
Or perhaps swapping a module from another 1996 Century with mine?
If I need a scanner, any recommendations??
Thank you
Thank you
