The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Explore Pet Insurance!
Advertise with us!
Привет. Самое неприятное это открутить три болта гидротрансформатора, для этого снимите стартер и вы увидите эти болты.Какой консенсус по этому поводу выглядит возможным. Я начал разбирать свой, чтобы заменить неисправный поршень № 4. Я тоже хочу вытащить его сверху. какова сложность отделения трансмиссии от двигателя в отсеке?
Was yours a manual?This job wasn't as bad as I had been worked up for. If you have a FWD model its pretty straight forward and it will come out the top pretty easy (no differential to fight) . Like omega said and the Chilton manual says watch your torque converter as you separate the block from the transaxle, it wanted to come with and I missed it spilling transmission fluid everywhere. leave the AC pumpin the bay out of the way and pull her up. I didn't even have to take the hood off. Good luck to those of you asking around on here. It can be done and it wasn't that bad. Ill update when the new one goes back in.
Any luck with this?2012 Regal GS 6MT. Time for engine replacement, is it possible to remove from top side? Any tips or tricks are greatly appreciated! Thank you!
Anyluck with this? I'm stuck on the same thingDoes anyone know if the auto transmission (fwd) will come out the top? It looks like it will to me.. I looked in Chiltons and it says to pull the front bumper cover and sub frame -
