G
G-115161
Books say a lot of things. Try and do it.It says in your cited manual pages that AWD wheels down is OK...... below 70mph.
I have a 2020 encore GX and have been pulling it for about 6 months now. Get the correct base plate installed but a goo grade tow bar. I also added the battery disconnect switch, whic makes it a breeze to hook up. My wife works for GM and they have said there is no problem towing this car. I am very happy with the way it tracks and pulls.Books say a lot of things. Try and do it.
We tow ours…. 2020 Encore GX. 1 summer now. Keep it under 70 and buy good tow equipment. Ignore all the na sayers. Listen to those doing it. I also added a battery disconnect switch which makes hook-up a breeze.We've been, doing it, for 1 year and 3,400 miles, no problems. Our 21 GX tows great,comfortable and gets great gas mileage.
Do you recall the wiring (wire colors) for hooking up the lights?Finished wiring taillights with diodes 3hrs,battery disconnect switch 2hrs, battery charger and brake a way switch 1hr. Very happy with everything, first tow all goods
I bought my GX and then explored the option of towing all wheels down but if you get the option package with the front bumper sensors (parking assist, I believe), you can’t use a tow bar. If you get FWD, you can use a tow dolly.
Thanks for reply .... I also never had a problem, just being extra cautious. Also just checked that setting remained in AWD mode, after having put it in AWD yesterday & wife driving it today stop & go several times .... setting stayed in AWD.We've left everything hooked up for overnight stops, just pull over shut off motorhome, wakeup and hit the road don't touch anything. Never had a problem.
We purchased a 2022 Encore GX AWD specifically because we wanted to flat tow behind our motorhome. For several months, have been working with Camping World to work out details of what equipment is needed and have hit a dead end. Even though manual specifically states that it can be flat towed, for some reason Buick will not commit to saying that it can be done (even after trying to get answers through various channels). Manual states battery must be disconnected but Buick seems unsure how brakes and steering will work without power applied. I'm at the point of not knowing what to do and considering purchasing another vehicle that I know will work. Very disappointed at the false claims by Buick and lack of support in getting information.I am considering purchasing a 2021 Encore GX AWD Essence for the purposes of flat towing behind a motorhome. I know the owners manual states it can be done and how to do it.
There appear to be several 2021 Trailblazer AWD owners doing this. We like the Buick interior better than the Trailblazer.
I'd like to know if any of you has experience in doing this and if there is anything to be aware of prior to purchasing the GX.
Because it's AWD and you can't disengage the rear wheels from the driveline. No AWD car can be dolly towed.
I bought a 23 encore gx. Roadmaster said I needed a battery disconnect. I bought the push button one. My question is when you disconnect the battery do you loose all of your electronic settingsI am getting our 2021 Encore GX AWD w/Sport Touring set up with Blue Ox equipment and Patriot brake system next week. I also purchased a roadmaster battery disconnect based on the info you provided here. (THANKS!) I wonder if you could post a picture of the battery disconnect in the wheel well. Curious how that's working out for you.
Garry Bergstrom
