Speaker Wiring - Adding a Subwoofer
steelblue48310
2019 Envision and Encore
Hello... New member here. I'm looking for the speaker Wiring diagram (or at least a color code) so I can add an aftermarket subwoofer. I don't have the Bose system... Just the standard radio. I found an under-seat subwoofer that will fit nicely under the larger rear seat, and it will need to connect to the rear speakers since the head-end unit doesn't have line-level outputs.
Thanks!
Well... After several months I finally got the subwoofer installed. Part of the delay was due to the fact that the car was at the dealership for weeks and weeks for a problem that is best suited for another thread.
Anyway, if anyone is looking for the colors of the rear speaker wiring, I can share this:
Left rear: Green / Green w/Black stripe
Right rear: White / Blue w/grey stripe
They are each twisted in pairs and a slightly heavier gauge than the other wires in the same harness. I was able to access each side by removing the kick plate at the rear floorboards.
The sub I bought was a self powered unit with both RCA and speaker-level inputs, which is why I needed to find the actual speaker connections.
Good luck with your project!
Update #2... Now I have to figure out where all the Active Noise Cancellation mics are. I found the one on the rear ceiling, but there's another somewhere... I disconnected the rear one but ANC system is still causing feedback in the Sub. Anyone know where the other ones are?
I figured it out... There's 2 more mics; one on each side in the grab handles above the front door. You can see the little holes in each. I ended up cutting the wires to the mic because I didn't want to pull down the whole headliner to unplug them. (Didn't need them anymore)
Now the subwoofer works great!
Just wanted to pop in and say thanks for the info. Despite nobody helping you, you continuing to come back and update helped me. Cheers!
3 years later, I'd like to ask, did the feedback occur continuously or just for maybe 10 seconds after you start the car. I had a powered sub in my Acura SUV with ANC and the feedback would occur for only about 10 seconds then it went away so i never bothered with the mics or disabling ANC. I would like to put the same sub in the Envision....
