DavidT
- Dec 3, 2022
- 96 Lesabre
So I did a Gasket job on my 96 lesabre. It was all stock and factory until I worked on it. Now I’m getting a whistling squeal but when I remove oil stick it goes away. All gaskets are correct I changed almost every sensor / valves that could be the culprit still to no avail. I noticed where the gasket for throttle body to Intake manifold there are little circle grooves that stick out half of one circle is broken could that be the problem?
