fuse box 1998 buick lesabre schematic
rojo
hi guys , where is the fuse box 1998 buick lesabre .
it under the hood or under the dash ??
the owners manual says under the hood , but car has a panel above the A/C
unit on the fire wall.
can someone please post a picture / schematic
of the under hood fuse panel
of my 1998 buick lesabre
many thanks, rojo
Those are the Maxi Fuses. Other locations for regular fuses are under the dash. One on driver's side and one on the passenger side below the glove compartment.
1 Battery Positive Cable Connection
2 LH Underhood Fuse Block
3 Low Speed Engine Cooling Fan Relay
4 High Speed Engine Cooling Fan Relay
5 High Blower Relay
6 Blower Motor Relay
7 Horn Relay
8 A/C Clutch Relay
9 RH Underhood Fuse Block
You're welcome.
There should be a diagram of the fuse/relays on the back side of the under hood cover. The OP did not mention what the problem was, or why he is asking this question??
hi guys , the horn is blowing all bye itself, either the alarm need s to be disconnected or the horn
require to know where the fuses are for each, please post,
many thanks, rojo
Sounds like the problem mine had. The connections in the steering wheel were bridging due to break-down over time. You can either disconnect the horn in the wheel (disconnect the battery first, as an airbag is dangerous!!!) and relocate it, or replace the entire steering wheel. . .
or fix the horn hardware...
Don't know how to do that myself, as the circuit itself is between the cover and the airbag, and they're molded together, as far as I can tell...
oh you meant that. Get an airbag lol
I don't think GM offers the airbag anymore & JY parts may have the same problem! Hopefully the OP found the fuse for the horn & another way to resolve the issue with airbag horn contacts during the last 2-yrs.
