Brakes on Encore GX
Sharvey
Encore GX AWD
At two years, the 2021 Encore STILL has terrible Brake Squeal. The dealer has no fix. Says its normal for GM cars due to new brake requirements. GM will need to make a fix - but after 2 years, that story is old and GM STILL has no fix for a faulty brake system. Buick / GM customer service is of no value whatsoever - just wants to have me take it to the dealer again and again. I have other cars, of the same age and they make no noise at all. Never have had a car that squeals like this. Horrible car - Horrible customer service. I'm sure they are betting you will get rid of it so they do not have to fix it. NEVER again will I buy a GM car if they cant even do brakes right.
Have you purchased a can of Brakekleen and tried cleaning the calipers and pads?
I have the same problem with my 2020 Encore GX. I bought it brand new, so I took it back to the dealership & they tried to tell me it was from moisture, I knew that was not the case. I have had my car for 4 years now and it still has that same annoying & embracing brake squeal. And no, the calipers & pads should not need to be cleaned on a brand new car off the lot. Any other siggestions/answers are greatly appreciated. Thanks!
spray adhesive between the caliper and the pad it'self. I just read it saw a vid saying the squeee is between the caliper and the shim. 🤔🤷
