Please help 2015 regal
jessie81
2015 Regal AWD turbo 2.0 4 cylinder
Need help 2015 regal awdt echo tech cannot find the oil pressure sensor or switch which ever you want to call it. Desperate there is nothing online with this particular engine.
You Googled "2015 ecotec oil pressure sensor location" and couldn't find anything? Could be spelling as two words.
It's above the starter.
Ok I have a new problem oil pressure control solenoid valve? Can anyone tell me or even throw a picture up of where this is at on the 2015 2.0 turbo 4 cylinder. It says block however that is not helpful.
Please post the code
So for 5 months or more you didn't try looking this up? See if this video helps. You are supposed to run diagnostics before replacing it.
