sniper60
- Jul 22, 2023
- Desert Southwest
- 2003 Le Sabre
It will start fine, run great for a few minutes and then stumble and die. Checked fuel pressure after it died and was only getting 12 psi, everytime you cycled the pump with the key the pressure would creep up a little. You couldn't hear the pump run before I replaced the pump and you can hear it run now, but it still dies after a few minutes. Also had a bad fuel pressure regulator/egr vacuum line that was replaced. It will restart, rev and die with half, or better throttle, after initially dying. Cleaned the MAF with no change. It runs great until it starts to warm up. I'm ready to pull my hair out, as I'm not the best with these computer controlled cars. This initially happened in a drive through and found the cracked vacuum line, but after replacing it the problem remained. It also has a very nasty smell from the exhaust after it dies and I try reestarting it, not "egg smell", but not right either. I can't describe it, but it's pretty rank. Any help would be greatly appreciated!
