Water leaking into cabin of buick lesabre 2003
Austin whiteted
Lesaber 2003
I have water leaking from what I believe is the ac into the cabin, I live in Florida so there is a lot of moisture in the air and there is a lot of water. What can I do to fix this?
It sounds like the evap tube drain is clogged & needs to be cleaned. The drain goes through the firewall & has a 90-deg bend that should drain to the ground. Have you noticed any water under that area after you drive & then park with the engine off? See Item #24 (View A) in the link below.
I found out it was blocked by the rubber peice. As it seems to have melted shut and now is working once I broke it loose
Dang, HotZ28! You’re one sharp tool! I’ve seen many of your posts on various forums, and you always seem to be spot on. Btw, I had the exact situation flood my c2500 cab. Thanks for sharing your experience.
Update on the car. The engine just failed and something internal broke deep within the engine.
:/ my luck is the best out there for sure
how many miles on the engine? Did it lose oil pressure?
