killeraxemannic
- Sep 10, 2023
- 2004 Park Avenue
My PA was leaking transmission fluid from the pan seal so the fluid was changed with a drain and fill as well as a filter change. The fluid used was Valvoline MULTI-VEHICLE (ATF) Full Synthetic. The car started shifting hard when driven for longer distances like 20-30 miles. I put some Lubegard 60902 ATF Protectant in it and it seems like it shifts faster and smoother however it still ends up developing the hard shift if the car is driven for long enough. I'm wondering if the fluid used isn't the best option and if I should switch it out for something else. Even though the Multi Vehicle fluid says it's recommended for Dextron vi, iii, and ii I noticed there are some more Dextron specific fluids available.
