90sbuickrescue
- Nov 4, 2023
- 97 Park Ave, 99 Regal, 97 LeSabre
Hello, I'm trying to figure out a few problems on a 97 park ave. I read through a few posts on this forum and decided to join after seeing what I would describe as a surprising amount of knowledge. I always figured buicks were cars that no one but mechanics worked on, (the opposite of a civic, where it is virtually impossible to find a stock one) but it seems that quite a few owners work on these too.
Anyway, the park avenue that I'm working on is a 97, non supercharged.
First thing is none of the interior lights work, and yesterday I tried to program a key fob (car did not come with one when I bought it from a tow yard) and that of course didn't work either. I checked the fuses under the hood, behind the glove box, and under the rear seat. There were 2 fuses blown in the under seat fuse box, #22, marked C/LTR, (15A) and #8, marked AUXOTLT (25A). Of course replacing those did absolutely nothing to solve this.
I suspect the body control module is at fault, I don't know what else to look at. I do not currently have any service manuals for this car. I also don't know if I buy another one on ebay, etc, what other problems I could be inviting. I know you have to reprogram key fobs of course, but what about the security, etc.
Next thing I would like to fix is the driver side wheel well motor mount. I cannot find that anywhere! Rockauto, partsgeek, etc, no one has it. I believe that mount is bad because the front and rear crossmember mounts have their cross bolts almost completely at the bottom of the rubber, with the rubber of course all torn apart. It looks to me like the motor/trans is held up/located front/back/side to side by the driver side wheel well mount and the passenger side wheel well mount (the one I had to mess with to a ridiculous degree just to replace the serpentine belt) with the front and rear crossmember mounts addressing powertrain torque under acceleration/deceleration. I could poly fill replacement front and rear crossmember mounts and use them to take all the load off the driver side wheel well mount, but that would be at the expense of more vibration transmitted into the car. However, it would still be better than what it is now.
There are multiple other things I would like to fix too, like the inoperative climate control/ac, front seats not going up/down, etc but for now I really just want to solve the lights/key fob, and figure out what to do with the motor mounts.
Thanks for any info!
