chibuick
- Oct 30, 2023
- 1996 Park Avenue, 1995 Park Avenue, 2002 LeSabre Custom
Hi all - recently purchased my 2002 LeSabre with 95k miles and would love to connect with other 00-05 LeSabre owners in the Chicago area or midwest. I'd love to discuss ownership stories, maintenance, rust prevention, general tips and "watch-outs", mechanic & body shop recommendations in the area, etc.
The previous owner had done much maintenance in the 3.5 years he owned it (bought at 35k and put 60k miles on it) including new valve cover and intake plenum and manifold gaskets, throttle body gasket, belt/tensioner, coolant elbows, engine coolant thermostat sensor, coolant hoses, water pump and gasket, motor and trans mounts, trans service, catalytic converter and 02 sensors (front and rear), spark plugs/wires/coil packs, brakes all around including new front calipers, new General tires, fuel sending unit/pump, fuel injectors, control arms, front struts, stabil links, axles, outer tie rods, rear air shocks and compressor, window regulators, HVAC blower motor resistor, ATC / ATM fuse holders and wiring (unsure what this relates to - just see it in the provided service records).
So far I've done new brake lines, power steering pressure & return lines, CV axles and outer tie rods, new seal on driver side CV axle to transmission that was leaking, battery, cabin & engine air filters, rust treatment (remove all rust from underside and carefully spray with CRC 06206 - what a pain).
Still to do: eventually new alternator since no records of its replacement, new fuel lines (pretty corroded currently) and welding new rear spring seats that I found nearly completely rusted out on both sides even though the rest of the car is pretty clean. This one caught me by surprise.
Even if you're not in the Chicagoland area, I'd still love to chat and share photos about any of the above and your experience with 00-05 LeSabre ownership! Thanks.
