saviorcrash
- Dec 16, 2023
- verano
I have codes p0097 p0641 p11c2 p2199 on my 2012 Verano. I already replaced the mass flow air sensor with a new OEM GM one off Amazon. I also replaced the High pressure fuel pump.
What led me to think it was fuel-related was when the car first wouldn't start I had the codes p0089 and p228D. These codes haven't returned, cause I think the car just doesn't run long enough for them to return.
These codes were also on the very first time I scanned the car....... Cam related codes p0340 , p0341 , p035 , p0366
then a bad cat code p0420 and a evap leak code p0442
The codes that are coming back instantly after clearing them all are p0097 p0641 p11c2 p2199. These point to a mass-flow sensor but I tried a new OEM one. IAT sensor 2 reads -40 , sensor 1 reads 73.
Has anyone else experienced this where the car wants to start but shuts off right away? I think the timing chain is loose but I wanna check all options before i take a peek in there. Thank you
