Chromium
- Apr 28, 2024
- 2003 Buick LeSabre
My 2003 Buick LeSabre is leaking coolant where the throttle body attaches to the upper plenum, so I'm planning to replace the plenum and upper intake manifold gaskets. I assume it would be advisable to replace the lower intake manifold gaskets and valve cover gaskets while everything is apart.
The only problem is, I can't see to find a replacement plastic plenum that has decent reviews. All the aftermarket ones, including Dorman, seem to have a lot of negative reviews lately concerning quality control, uneven gasket mating surfaces, gasket fitment issues, etc. Has anyone had luck with a particular brand for this repair? The options appear to be very limited and obviously I don't want it to leak when it's all put back together!
Alternatively, can I just reuse the plenum and install new gaskets? The plenum and upper and lower intake manifold gaskets were last replaced back in 2007 when the car only had 16k miles. I assume they used the revised plenum that corrects the issue of EGR gasses melting the plastic, but with the car now having 238k miles, I'm wondering if it might be slightly warped, which might be causing my leak.
I would appreciate any advice or suggestions!
