2018 TourX in Texas
- Dec 25, 2022
My issue MAY be related.
Not a popping noise but a low frequency vibration noise (thought a branch was stuck under the car) - only evident at low speeds like maneuvering a parking lot & only with steering wheel turned L or R.
Noise fades above say 10mph & completely disappears when going totally straight.
Was thinking it could be differential related ?
Just changed rear & front diff fluids using proper spec fluid - maybe rear needs more anti slip additive ?
I will raise rear & verify lube level unchanged.
Any ideas I'm all ears & thank you ahead of time !
David in Texas
David in Texas
