Hi Larry. Thanks for your answer. I will go on searching. Sincerely. MichelIt's discontinued. Your best bet is Ebay, or Car-Part.com--Used Auto Parts Market
Thanks. I will check through it. Sincerely. MichelHere's another post/source on the part number that may be helpful.
Auto Level Control help on 83 Eldorado
Looks like my Relay for the auto level control is out. Part number is 25515069 . Anyone know where I can get one of these or can it be fixed? The compressor works if I hot wire it. Fuse is good. Repair manual says most likely problem is the relay. Here are a couple pictures. Thank you, Joewww.cadillacforums.com
I confirm it to be discontinued.It's discontinued. Your best bet is Ebay, or Car-Part.com--Used Auto Parts Market
