The car lovers social network
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Explore Pet Insurance!
The Food Order Method
Buick parts & accessories
Advertise with us!
I had the same exact problem and Movedon is 100% right. It's the bracket on the back seat which applies pressure on the fuse box, in turn applying pressure on the fuel pump fuse burning them out. You have to cut a piece of the seat bracket off and be weary of having too much weight in that back driver side seat. I burnt 3 fuses in about 3 weeks, and it also almost fried the entire fuse box. I took the fuse box out, and opened it up (which was very difficult to do). There are these little metal clips that hold the prongs to each fuse, that was toast and corroded from the repeated frying of fuses, so I took one out of the good looking clips out of a cigarette lighter that I never used, and put that on the fuel pump fuse spot that was faulty. Those little tiny metal clips were impossible to get so I had to makeshift it. Never happened again..
Although now the car at 79k is blowing smoke out of the tailpipe and i'm worried I have a blown head gasket with misfire cylinder 3 and service stabilitrak codes... Long story short, this car is very poorly designed and I would sell it ASAP before some BS happens to you
Sorry for the long read but I'm going to copy my original post for this to give you some background of exactly what is going on. Thank you for your time!This is all a VERY simple job to do. Had mine in and out in less than three minutes. What year is yours? Mainly meaning, what engine is in it? If a Northstar, the cylinder head bolt issue was MOSTLY fixed by the time it was in these. If is the 3.8, lower intake gaskets are common, and dead easy. If the 3.9...those are great engines. What colour is the smoke?
Replace the fuse blockMy fuel pump relay has burnt out twice in less then a week. What could be causing it to do that?
