M mlizotte Member Joined May 21, 2021 Messages 70 Reaction score 14 Points 8 Buick Ownership 04 buick lesabre custom, 01 buick lesabre limited Sep 10, 2024 #1 I see that my coolant temp. goes back and forth from 212 to 224, is this normal operating temp. ?
02LTD Well-known member Joined Apr 18, 2022 Messages 954 Reaction score 577 Points 93 Location Long Island NY Buick Ownership 2002 Lesabre Limited Sep 10, 2024 #2 Yep….anywhere from about 200 to 225.
JGBuick Sustaining Member Joined Jun 8, 2020 Messages 947 Reaction score 535 Points 93 Buick Ownership 2001 LeSabre Touring Edition Sep 10, 2024 #3 Just took a 4K cross country trip... My temps never went over 218degs and that was climbing steep mountains in the AZ heat. Most of the time on the highway, it stayed steady around 200degs.
HotZ28 Full Member Since 2005 Joined Jul 1, 2005 Messages 11,281 Reaction score 2,511 Points 113 Location SE Buick Ownership 1996 Roadmaster Limited Collectors Edition 58k - 1996 PAU 2019 Regal GS Sep 11, 2024 #4 mlizotte said: I see that my coolant temp. goes back and forth from 212 to 224, is this normal operating temp. ? Click to expand... That may be normal if the A/C is not active to turn on the radiator fan(s). If the A/C is turned ON, that may not be normal. ______________________________ Help support this site so it can continue supporting you! M mlizotte Member Joined May 21, 2021 Messages 70 Reaction score 14 Points 8 Buick Ownership 04 buick lesabre custom, 01 buick lesabre limited Wednesday at 2:40 PM #5 Just went to 227 for a sec. then went back to 187 to 201. Should I worry now? it happened as I was turning in a parking lot. How would a shop try to fix this?
