chrisbek100
- Sep 9, 2015
- Buick
So I recently got bought a nice blue colored buick lucerne clx 2006 with the 3.8 litre engine about 2 weeks ago. The car is in pretty good shape.
I am slowly doing some some tune ups on the car and decided to change the oil.
I have no idea when the oil was last done but figured I might as well do it before winter hits.
I jacked up the car and tried to turn the oil drain plug.
It was on there tight. Like super super tight. Seems the last person who did the oil change went nuts on this plug and really torqued it down. I can only assume with an impact gun.
I tried to get a 6 point socket on the oil drain bolt but there is not enough clearance to attach the ratchet and a 13mm socket due to the transmission pan being in the way.
I tried a crows foot which has 5 points of contact but the drain plug is on really tight.
Tried to use a regular wrench and still it would not turn.
Tried to use a propane torch to heat it up.
Still would not budge.
Eventually the head on the hex on the drain plug bolt became deformed and is slightly rounded now and won't turn using a wrench.
I have purchased a bolt extractor kit here:
www.canadiantire.ca
Should I use the 13 mm bolt extractor or is there a better way or solution to get this bolt out?
Friend suggested vice grips but I just don't want to deform the hex bolt anymore using a vice grips.
Figured I would ask here with those with more experience before I make something worse.
I have never had this problem ever before with my other sliver colored 2006 cx when I did oil changes on it. I always tighten the oil pan bolt hand tight and give it a nice slight turn and ensure its on snug and perfect. It always came off easy and always went back on easy.
General PDP Template
