HID Headlights conversion
If you're still looking, I put leds in my PA. I removed the wire for the DRL and replaced it with a ground wire. I currently don't have DRL, but the headlights are brighter. As long as you buy leds with adjustment they won't be blinding to people. My plan at some point is to get a relay that gets power from the DRL circuit and power some other lights for DRL. I only unhooked the DRL because the high beams flickered from the lower voltage when the headlights are off.
Can you share what brand of LEDs you're using, please?
Also, would you be able to snap a pic or two of them shining on a wall and/or the roadway? I have LEDs in my Chevy sedan, but they're H11 and H9, but the LeSabre takes 9006 and 9005.
Thanks for considering my request.
Looking at some literature for the F16 auxbeam , they support 6v DRL on the 9005 high beam, but it wasnt 100% confident inspriing the sources I used
Gonna bump this thread back. I wanna put 9005 leds in my drl, but I don't wanna lose the drl so I searched Amazon for the f16 auxbeam and they don't appear to sell them anymore. Any ideas?
I forgot what year you have
9006 is drl in 2005
2000-2004 is the 9005
2002 used the high beams at half power for the DRL function.
04 lesabre. 9005 for high/drl. You said you got the f16 auxbeam and it worked with the drl. I can't find them for sale on Amazon.
yes , so the high beams are right.
i see the "F16 plus" on their website, so probably amazon
they also sell "F15" which are budget option
They both appear higher build quality in the photo than mine are, so maybe worth a chance
But same issue, they state 9v as lowest
but i dont rememebr what my f16 were
I may buy them to see if they function with the drl option. If not, I'll return them.
Something to remember with DRLs and LEDs:
  • DRLs like yours are wired in series, which means that the incandescent high beams function as two different types of lighting. When in parallel (the normal setup), they send full voltage to each bulb, allowing them to act as very bright high beams. When in series (for DRLs), they split the voltage in half, allowing the bulbs to burn at reduced power and brightness.
  • LEDs can run at lower voltages (e.g. 9V) because they have a boost-or-buck module, which is fancy-schmancy talk for a module that stabilizes the voltage by either boosting it or by lowering (bucking) it. In either case, there will be additional heat in that module, and heat shortens the lives of electronic components. When it attempts to boost the approximately 6-7V that the DRL is providing, they may either turn on at full brightness, or not turn on at all due to being below 9V. The boost is accomplished by drawing more amperage, which may also cause concerns for your fuse(s) and relay(s), but probably not immediately.
My opinion is that anyone driving around in the daytime with full-brightness high beams ought to have their heads examined! My eyes are more sensitive to glaring light such as the kind that comes from LEDs, especially the "super-bright 6500 Kelvin" bulbs that seem to be the rage. Even in the daytime, they bother me enough that I get headaches from them. At night it's even worse.
As a human, you will see better at night using bulbs rated around 4500K. While they may not be as stylish and trendy, they are much more useful and a lot less of an irritation to folks like me whose eyes are more easily hurt by glaring light.
I decided not to do led high beams because I don't want to lose my drl feature. Instead I'm going to keep the 9005 yellow halogen bulbs I put in about a year ago. They work great as drl and even better as high beams in the rain and fog.
That is a really intelligent decision. I'm proud of you for making that decision and sharing it with others!
only because you have a lesabre, i will not fault you, but you do know that your car automatically turns the headlights on with continous wipers?
the park avenue does not, relying on the DRL in the mist/fog is dangerous when its bright out, because you can see but your car is NOT illuminated in the rear.
If youre in fog you NEED to turn your headlamps on if you werent using your wipers if its bright enough your dash isnt being backlit, meaning twilight sentinel isnt turning them on
also you could try the LED thing, ive never noticed my DRL to be bright despite being the LED, ive seen it by setting park brake in gear (off) and using windows at businesses since the DRL turns off in park
