timreevessr
- May 14, 2025
- 2012 Buick Verona leather edition
I put new plugs and coils in it and it did not change anything but it needed plugs bad. When you first give it a little bit of gas to go to take off and reverse or forward it will stall out but if you hold your foot on the brake and give it gas and let go of the brakes so the RPMs are up It will go just fine. I thought it was the fuel filter but it's supposed to have a lifetime fuel filter from what I understand. The scanner did say something about the cam sensor. Could that be a problem and it also said about the O2 sensors. But sometimes when one thing isn't working it will show a bunch of different things not working correctly. Has anyone encounter this because I read it on some other thread that was from 2022 but I never found out a cause or how to fix it. Really needing help before she gets hit or hits someone else.
