Jerano
- Jun 28, 2025
- 2012 Verano
Hello everyone. I'm new here. I am trying to help my son out with his Verano. He's had it several years. Unfortunately, he hasn't done the best job of keeping his oil topped off and clean. Currently he has almost 160k on it. I've changed both of his vvt's in the past and the 0014 and 0015 codes went away. The P0014 has come back and changing the intake vvt hasn't helped. I also threw in a new censor to rule it out since it was inexpensive, easy, and I really don't have any way to diagnose the problem with just a code reader. Some searching has suggested that the timing chain could also be a cause from stretching. Should I change both chains or seek a professional diagnosis first. The shops want $200 dollars and I'm not sure I would get the correct answer. In the past he had it shut the ac down due to high engine temp and the guy at the shop wanted to just change everything the codes suggested without even doing a proper diagnosis. TIA for any help or suggestions.
