2007 CXS brake module replacement now no start
2000 PA
I put a used brake module on and now it won't start. Just clicks. I can't get my scanner to connect either. Surely a brake module doesnt need vin programmed?
I checked all the relays and fuses under back seat and under hood. I didn't see any vlown fuses. I swapped ignition relays and it didn't help.
Anyone have any advice. Thanks.
No start or no crank? Not clear on details as a module shouldn't have created the problem.
So
Starter.
Just went through this or similar to this. And had to replace the starter. My traction control and brake lights was flashing on along with check engine light. Think this was all results from spark plug and wire replacement gone wrong.
