Albertlong92
- Nov 23, 2023
- Lucerne 4.6
So my CXS started to run a little weird and I knew I needed to do some suspension work so I parked it and ordered parts, I would remote start it and let it run off on its own once a week. One day I came out after about 3 weeks of not driving it anymore than a couple hundred feet in my parking lot and the right front brake like was busted right in the front under the radiator support. I replaced it and bled it out three separate times and still have no pedal. This is the second time I've had to remove a brake line from the abs block so I'm a little concerned about that though I was careful and covered/cleaned everything in the area. Is there part that this year and model is known to go bad and cause no pedal? If it's a master cylinder does anyone have a link to a site where I can get a rebuilt kit for the master cylinder or where I can get a good affordable abs block?
