5.0MX5
- Jan 27, 2019
- 1998 Park Avenue, 2001 Park Avenue, 2005 Park Avenue
I mentioned this potential solution for a non working gas gauge on another post. If your PA’s sending unit is bad, this tip no workey. But, if the needle is on the wrong (bottom) side of the stop needle it’s easily reset. All it takes is a small super magnet. I’ve got a dozen or so that are about 1/2” square x 1/4 thick. I stack 5 or 6 together.
The magnets, when placed at about the 2 o-clock position above the needle will make it swing back into position.
Gas gauge works, no holes to drill in the plastic or mess of any kind. The needle will sometimes flop around when the battery cables are disconnected/reconnected.
RonR
RonR
