serialusr
- Aug 15, 2024
- 2010 buick lacrosse
Ive got an issue with my exhaust bank 2 vvt actuator solenoid. It will not advance when I command it with the scan tool. The other 3 work fine and increase at 5 digit intervals. Its causing me to fail inspection and it idles and runs rough at times.
I had 2.6 volts going through the harness to the solenoid. Now only shows 0 volts. Traced wires to ecm, no issue.
Solenoid works when 12v is applied and measures 10.5 ohms.
Also 3 drive cycles will not complete.
Got a new ecm from flagship, pre programmed, and the hardware and service codes dont match. Cant get it to work. They say it should still work.
Anyone think they know why the scan tool will not command 1 solenoid? ECM? Grounds?
Thank you , this has been a pain and costly.
About to buy something else, but I love this car.
Greg
Greg
