LARRY70GS
- Jul 28, 2004
- Oakland Gardens, N.Y.
- 70 GS455 Stg1
Again, the tires will show negative camber if the ride height is too low. Failure of the level control system is common. Mine was not working when I bought my 98 in 2004 at 85K. I used the FSM to diagnose and fix mine. It still worked at 212K when I sold the car this year. If I had it to do again, I would just eliminate the whole system and use the coil over shocks to correct the ride height. There is no adjustment for camber at the rear, it depends on proper ride height.
