2011 regal air conditioning problems
Tatr
2011 German regal
My 2011 regal has an air problem. Blows warm air fo several minutes, than starts to blow cool air, any ideas on the problem?
That's pretty normal for any car that's been sitting out in the hot sun.
Roll down the windows until the AC gets cool, then roll them back up.
That should cool it down a little quicker.
Check your coolant level. It could be low.
I assume you meant to say refrigerant level? I don't understand how the "coolant level" would cause this problem? Educate me if I am wrong!
Looks like I rushed to reply, instead of realizing OP's issue. 🤦‍♂️ Low coolant causes the heat in the car to have issues, not the a/c. Thanks for catching this.
Check the refrigerant level, have it topped off (if necessary). If the issue happens again, there could be a leak somewhere.
