Triggerology
- May 16, 2025
- 2002 LeSabre
Hey everyone. I have a 2002 Buick LeSabre with 55k miles that I just got recently and she's got a P0171 code. I took her to a mechanic to be diagnosed and he found a few things that needed to be done to the car. I've never worked on cars before, so I'm hoping y'all can point me in the right direction while I come up with a game plan.
I'm thinking about tackling the brake booster with SKP SKBB018 and serpentine belt with GATES K060926 Micro-V first - to get rid of the code and the serpentine belt is cheap and (looks) easy. Does replacing the brake booster require bleeding the brake lines afterwards? It looks like I may just be able to move the master cylinder aside without disturbing any of the brake fluid.
As for the shocks and struts, I'm thinking of buying a complete assembly for the struts, so I don't have to worry about compressing the springs. I don't really want to cheap out on suspension parts, so I was thinking of going with GABRIEL G57051 Ultra ReadyMount. I'd like to keep my rear air shocks and figure out what's wrong with the compressor, so I'm thinking of going with GM GENUINE 504147 and GM GENUINE 504146. Do y'all think there are better options out there? If anyone could provide some troubleshooting tips for the air compressor, that would be great! If it turns out it's shot, I'll probably wind up buying DORMAN 949015.
Is there anything I need to know regarding the wheel bearing? Any specific tools to remove them? I did not receive a video on this to confirm this is an actual issue, so I'm willing to hold off on this.
Appreciate any and all info y'all can provide. Thanks in advance! Some pics of the car and parts below!
- Brake booster is leaking
- Serpentine belt is starting to wear and has some slight cracks in it
- Rear air shocks are leaking oil, advised both need to be replaced along with front struts
- Air compressor for the suspension isn't turning on and one of the air lines is missing/deteriorated
- There's some play in the front wheel bearings
