Raden
- Nov 13, 2020
- Rendezvous
While investigating a coolant leak, I found the plastic filler neck on the pass side of the engine bay has cracked and is leaking. When removing it for inspection, it basically crumbled and is no longer usable. I was hoping to use some JB weld or something, but it's not an option. Calling GM, they say the part is discontinued and no dealer in North America has stock. There are no aftermarket parts listed for it. The closest wrecker listing a 3.6 is in the southern states, no way to check if the part is still available and im in Canada. Not sure what to do.
Anyone come across this issue? Some other aftermarket part that I can use as a substitute?
