Air stuck on defrosters
Synna
Park ave. Surpercharged ultra
I have a 99 park ave. Supercharger ultra and it’s been stuck on the top air vents since I got it. I’ve tried searching the problem and only finding things for the LeSabre. Is there a way to fix it?
Typical blend door failure!
I had a 1998 Olds 88 that would always blow through the defroster vents. I had a vacuum leak right before the vacuum line goes through the firewall to the HVAC unit. A one and a half inch piece of vacuum hose solved the problem.
I don't remember if the '99 was vacuum controlled actuators, or electrical servo controlled. Maybe someone here can help clarify.
First, the good news. I know what's bad, it's the electric motor driven mode actuator. As you're setting in the car, it's to the right of your right knee, below the radio. At 74 years young (old?) I replaced one this year. So, it's possible, however it was a challenge for me anyway. I'm 6' and 165 lbs and it was a challenge to wiggle into the available work space. Details HERE.
It does seem the recommended replacements are now made of unobtaintum. However the most common thing to fail in mode actuators and other actuators is a large plastic drive gear and you can buy those online. Easy to change.
Good Luck,
RonR
At 74, you are just a kid in my life!
Thanks but today I’m not too spunky. While riding the rough edge off a new horse a month ago I failed to grab leather during a bucking moment. Wound up on the ground with a kick to the head and arm resulting in broken radius and wrist. My wrenching is in SLOW mode!
Not sure what that means, but she's an arena horse (barrels) we were breaking her out in a new environment with wagons and rodeo events on an open range. Not her fault.
You got thrown, but instead of saying that, "you showed her who's the boss", when in reality it was her who showed you.
