BUICK CENTURY
 - Dec 18, 2022
all was well... til sitting in drive thru, on 110* day, wind wrong way, and temp gauge went from a little over 1/4 gauge (normal) to 1/2 a gauge. never did that before. open radiator cap, chocolate mocha mix in the filler neck and in recovery tank.
changed anti freeze with generic WM brand anti freeze. added stop leak pellets. changed radiator cap to 7psi cap instead of 15 PSI cap figuring if it is going to blow anything anywhere, i wud rather have it blow the anti freeze into the overflow than the water into the oil, thinning the oil.
so, question is... is it intake gasket leaking $$$ to fix or is it HEAD GASKET $$$$$$$$??? i read some on it, seems like intake gasket ??? that is easier/cheaper than head gaskets. car is not worth that much $ even with low miles on it. i really do not want to put BIG $$$$ into head gaskets that will cost MORE than the car is worth, in the condition it is in. 20 years old now. runs ok. no check engine light. got OBD II thing off e bay. the temp on it shows abt 205* a little less than half a gauge on factory dash gauge. thats not too bad... so far. i doubt if it is going to get any better the more i drive it, what little i do drive it.
