Rally Sport
 - Jul 13, 2025
 - 2008 Buick lacrosse cx
Does the 2008 Buick Lacrosse cx have a TPMS reset button and if it does where is it located?
				The only time you should need to 'relearn' the TPMS is when a tire rotation is done and every dealer/tire center is supposed to do that. They often miss that part of the process. But you can also buy a cheap relearn tool, as I did. It worked on my 2013 Cadillac ATS and also works on my 2018 Buick Lacrosse. Read your manual to learn how to relearn using this tool.
Relearn Tool for GM, Auto Tire Pressure Monitor Sensor Activation Reset Tool, Automotive Tire Sensor Reset Tool, System Programming Training, OEC-T5, for GM Series Vehicle 2006-2023 - Walmart.com
Buy Relearn Tool for GM, Auto Tire Pressure Monitor Sensor Activation Reset Tool, Automotive Tire Sensor Reset Tool, System Programming Training, OEC-T5, for GM Series Vehicle 2006-2023 at Walmart.comwww.walmart.com
I found out what was wrong one of the sensors is not working.The only time you should need to 'relearn' the TPMS is when a tire rotation is done and every dealer/tire center is supposed to do that. They often miss that part of the process. But you can also buy a cheap relearn tool, as I did. It worked on my 2013 Cadillac ATS and also works on my 2018 Buick Lacrosse. Read your manual to learn how to relearn using this tool.
