The car lovers social network
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Buick parts & accessories
Advertise with us!
Advertise with us!
Al, I do not know of anyone who offers a metal replacement elbow for the 1996 Series II Vin-K bypass, which is a totally different design from the Series I Vin-L plastic nipple. Dorman does offer replacement plastic elbows, but some who have used them complain of the O-rings being too small, which allows coolant leaks when cold. I recently replaced my tensioner and installed a new OEM elbow (with O-rings) from the dealer and all is well. For more discussion on this subject, Click Here BTW, the tensioner has to be removed to replace the elbow.
I know this is an old thread, but wanted to add, for anyone else like me who stumbles on to this, that there is a second GM part number that goes with p/n 24503423. That is just the upper elbow; the lower elbow is GM p/n 12565082.The plastic elbow is called a "pipe assembly" by GM, Part #24503423. List for less than 15-bucks @ the dealer, but if you have time, you may want to order one from Rightnowautoparts for $8.89 plus shipping; either way, they are cheap! I forgot to mention, disconnect the negative battery cable & remove the alternator, in addition to the tensioner for better access.
Welcome to the forum Doug and thanks for posting. However, for the benefit of others, we need to make it clear that this thread was originally discussing the coolant elbow for an 1996 PA which does not use the lower plastic elbow. This would also include 1995-1998 VIN-K & VIN-1 engines. IIRC, the lower elbow Part # 12565082 was not included until 1999.I know this is an old thread, but wanted to add, for anyone else like me who stumbles on to this, that there is a second GM part number that goes with p/n 24503423. That is just the upper elbow; the lower elbow is GM p/n 12565082.
Doug...making my first post here...
Thanks for the clarification, HotZ28. Good point.Welcome to the forum Doug and thanks for posting. However, for the benefit of others, we need to make it clear that this thread was originally discussing the coolant elbow for an 1996 PA which does not use the lower plastic elbow. This would also include 1995-1998 VIN-K & VIN-1 engines. IIRC, the lower elbow Part # 12565082 was not included until 1999.
Hi, HotZ28. I found them at Rockauto under:Anyway, where did you find the "metal elbows from Dorman"? Many of us have discussed the advantage of using metal vs plastic for this application and why GM has never recognized this as an improvement, or option. If you could post a link, of just give us a hint to where you found the metal elbows, it would be appreciated.
I do recall reading that!BTW, I don't remember where, but I did a post discussing the difference between OEM elbows/o-rings and Dorman. The best I can remember, the Dorman elbow is nearly identical in dimensions, but the o-rings were made of a different material and slightly different size.
Yes, the coolant has to go somewhere 🙂 I've seen a pic - danged if I can find a good one now - showing the different setup that uses only the one elbow. But, yes, the coolant does indeed circulate thru the tensioner housing. I'm sure others here who've dealt with the single-elbow version of the motor can elaborate on this.I want to ask, doesn't there have to be another port on the tensioner housing?
Off the top of my head, I can't recall which way to turn it, but you'll be able to tell with no problem. To swing the tensioner arm, you insert a 3/8" socket driver into the square hole on the tensioner. Don't put a socket on the bolt.When I remove the serpentine belt, do I put a socket right on the tensioner bolt head which is also through the center of the tensioner pulley? And the tensioner is spring loaded I think right? Push the wrench counterclockwise to slacken and remove the belt, and slowly release the wrench clockwise to allow the springs in the tensioner to increase tension on the belt - is that correct too?
