02 rendezvous freeze plugs
Jsquare66
I've got coolant leaking. Lose tracking behind idler pulley next to water pump. I was wondering if there is a freeze plug around that area that might be leaking. Thanks for your help!
No freeze plugs on the front (pulley side) of the engine, but the water pump should have a weep hole, it may be coming from it and working it's way across the engine or belt.
If it is a 3.4 then there is a core plug on the front side of the front head right behind the water pump.
