Dave85
- Nov 12, 2025
- 2003 Le Sabre
Hey all, I’m new here and am looking forward to hearing from everyone.
I have been chasing a P0300 and P0304 code for weeks now and I can’t figure it out.
After I troubleshoot one thing and plug it all back in for a drive, I initially get the random misfire code. I’ll stop, remove the code then drive a little more and the cylinder 4 misfire code will pop and stay consistent. I’ve swapped coils to see if it travels and it doesn’t. I swapped a couple plug wires with the same result. Today I removed the fuel rail and checked the injectors. They all looked fine so I swapped the cylinder 4 injector with the cylinder 6 injector and still got P0304 misfire code. The car idles great and if I give it gas and hold at 3,000 rpm, it runs fine. It starts the misfire while under a load at higher rpm. When it’s actively misfiring, I can hear a noise that sounds something like an intermittent sucking or intermittent blowing. All plugs, wires, coils and ICM have been done. Replaced the cam and crank position sensors. Checked extensively for vacuum leaks. Also replaced the fuel quick connect and fuel pressure regulator. I just don’t know where to go from here.
