"disable traction you should pull the two maxi fuses under hood for pump and valve and then the 3-4 fuses iirc in the fuse block."
Relay center passenger side under dash shows an unlisted #3 & 4 fuse.
Fuse block inside cabin #3 & 4. Gotcha. Except I do not see anything associated w/ABS on those fuses. Unless you are referring to the fuses under the relays inside cabin over on passenger side up inside the dash that also contains the fuel pump relay. See diagram above
The fusebox diagram I found shows #13 & 19 as antilock fuses. See above.
Under hood maxi-fuse 1 & 2 + #5? See above.
These diagrams are supposed to be for a 92 PA though Ultra. I figured the same on non-SC model as mine. I've checked the fuel pump relay under the dash on the passenger side.
Well, I've been notified they lied about brake hose delivery today. No mention when just not today.
So, I guess I'll pull the fuses once the temp climbs above freezing and see if anything changes.
ETA II: Fuses
Looking from the front of the auto the second set of 8 maxi fuses #1 ORN 40A & #2 LT GRN state ABS. My #5 RED 50A, as shown in the diagram I posted shows DR LK -next line-MISC-next line LGT. Since mine, unlike the alleged 92 Ultra, doesn't have an ABS sticker on #5 I'll leave it in.
My fuse block drivers side under dash that flips down has 2 metal box circuit breakers of 30A in fuse #3 & #4. I'll pull them ignoring the diagram I posted showing #13 20A & #19 10A being anti lock also ignoring 3 & 4 fuse on the bottom of the relay fuse box over on the passenger side under the dash.
Sorry for the confusion. I guess what I posted that was supposed to be for a 92 ultra is not the same as my basic 92PA
ETA II: Fuses
