Ok so I have a 1998 Regal LS nonSC Auto
Was having problems with A/c blowing weak at the dash vents and I thought it was the Passenger Air scrubber. I replaced it as I couldn't remember when it was last done. Didn't solve the problem but the air smelled better (no more rotting plant life). So I noticed that the bi-level and dash ducts were engaged even though The control was set to norm. After checking the obvious stuff (fuses, resister, relay, and running a 12v direct jumper to blower) I started checking vacuum lines. The 1/8 inch plastic line running from the intake at the power brake booster junction was intact. This line at one time gave me a PO440 code awhile back when it was pulled loose after taking off the engine noise silencer. So I figured this was not the problem. However I remembered that this problem began after a battery change. So after following the plastic line down and around the fender skirt just before the battery there is a tee one side runs to the vac tank under left fender. The other I don't know where that one runs. Anyway, the line running to the vac tank was brittle and when the battery came in contact with it must have snapped the line. Repaired with a piece of rubber line. All is well now.
