ede smith
- Apr 8, 2021
- Century
Calling All 1997–2005 Buick Century Owners!
I thought it would be interesting to hear what other folks have repaired, replaced, or still need to fix on their Century.
Please comment below with:
That’s where I’m at for now. I’m sure I’m forgetting a few things, but my goal is to get past 200k miles and beyond.
Now it’s your turn — post your Century’s:
- Your model year
- Current mileage
- A list of repairs you've done or plan to do
I'll go first. Here's my update:
2001 Century – 160,000 milesLocation: Midwest / Rust Belt
🔧 Brakes
- Rotors: Replaced at least twice — due again due to condition, even though not below discard thickness.
- Pads: Replaced 3 times, last time was pad slap.
- Rear Drums:
- Replaced leaking wheel cylinders
- Believe I also did shoes and hardware at around 50K
- Brake Line:Replaced one section (passenger side to ABS module).
- Planning to install this copper-nickel tubing kit before winter:
3/16
- E-brake cable: Snapped. Not sure I’ll replace it.
- Brake Fluid: flushed when doing rear cylinders and front brake line.
🚗 Steering/Suspension
- Wheel Bearings (front): Both replaced
- Outer Tie Rods: Replaced
- Sway Bar Links & Bushings:Replaced
- Pinch weld failed — welded back instead of dropping the subframe and entirely replacing sway bar
- Alignment: One done so far
🌡️ Cooling System
- Radiator:Replaced
- Also replaced coolant temp sensor (tough to reach behind the radiator)
- Still chasing low coolant warning
- Water Pump: Replaced 3 times
- Last time probably unnecessary — leak was front timing cover gasket
- Gaskets:
- Intake upper and lower manifold gasket(common on 3.1 engines)
- Tech replaced thermostat and flushed coolant at the same time. One job I sourced out.
- two of the injectors he had problems removing, brittle plastic, and they were replaced.
- valve covers
- Front timing cover gasketwas leaking
- I replaced last fall
❄️ AC
- Still running on original charge
- Noticed metal shavings near the compressor clutch last fall
🛞 Power Steering
- Was groaning on turns
- Cleaned vent cap
- Replaced some fluid after siphoning old stuff out
⚙️ Engine Sensors
- EVAP purge valve: Replaced (emissions code)
- IAC valve: Cleaned — huge improvement for idle
- Throttle body / MAF: Cleaned (MAF cleaned every air filter change)
🔌 Electrical/Ignition
- Plugs and wires once
- Alternator: Replaced twice
- Serpentine Belt: Replaced 2–3 times
- Starter: Replaced (AutoZone brand, occasionally sounds off)
- Instrument Cluster: Re-soldered as mileage indicator was no longer lit.
- Driver side window motor
- Right rear window regulator
- Trunk Harness: Wires were pinched — spliced and soldered
⛽ Fuel System/Exhaust
- Fuel Pump:Bosch replacement
- Left rear seat out since repair — don’t miss it
- Crimped the harness (may upgrade to Klein ratcheting crimper)
- Learned crimping is better than soldering for vehicle wiring
- Fuel Filter: Replaced at least once — caused leak from rusty fittings
- Fuel Line:Replaced a small section by the filter
- Hard to bend due to tight radius
- Shop said they smelled fuel — I haven’t noticed anything since
- Exhaust pipe
- Welded hanger back on near Cat
🔧 Still needs work
- Lower Control Arms:
- Bushings are bad, and ball joints are original
- Planning to replace entire control arms
- Not impressed with RockAuto options — leaning toward Mevotech Supreme as Moog RK models are not supposed to be very good.
- Struts/Springs:
- Still original
- Aftermarket quick-struts don’t seem great — haven’t pulled the trigger yet
- Tires:
- Junkyard Pirellis — still have like new tread but are 10 years old
- Need to be replaced but difficult to find decent 205/70/15
- Calipers/Hoses:
- Still original — thinking about replacing.
- Transmission Service:
- Fluid has never been changed
- Planning a drain-and-fill(no flush)
- Replacing filter, gasket
- Capacity: ~7.4 quarts (no converter)
- Will do 1–2 more fluid changes later to cycle in fresh fluid
- Cooling System:
- Hose Clamps: Replacing worm-drive clamps with constant-tension types. This could be the source from what I am smelling.
- Electrical:
- Door lock actuator is sticking on front passenger door. I haven't heard great things about aftermarket ones.
- Body Control Module Issue:
- Strange intermittent dashboard lights
- Removed piezo siren from BCM, haven't resolved issue though
- More details here
- Fuel Line:
- Would like to replace more (or all), but unsure where to start
- Piston Slap:
- Happens in cold weather — disappears once warm
- Year
- Current mileage
- Repairs done / planned
